Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › NostalgiTone – Vibe trouble
- This topic has 8 replies, 3 voices, and was last updated 2 years, 4 months ago by
June 11, 2024 at 11:30 pm #32487
GuestHello:
I’ve built the Vibe (love the purple!) but only get a whine when engaged. I hear the whine rate and intensity change when knobs are turned, and pitch changes with Voice knob turned.The yellow LED that came with the LDRs that I got from GPCB does glow and pulse, as I suppose it should.
Does anyone have the voltage readings for the ICs that I can check against?
I have a probe, but not sure where to start. This is my first ever vibe pedal.
I do get bypass signal with no problems.
Thanks for help!
June 12, 2024 at 8:13 am #32490Anonymous
GuestI think I found problem; let me know if this is true.
I had difficulty with 3pdt board; I think it’s upside down. However, I have “out” on pub to “out” on 3pdt board. Not sure if that is correct.
See photo. Thoughts?
Also, what are the 4 holes around the LDR/photocells for?
tx,
jeff
June 12, 2024 at 1:50 pm #32491
BarryKeymasterThe 3PDT wiring board is backwards.
Wiring Diagram
You will need a new wiring board. I suggest carefully heating and removing the wires from the 3PDT board only, to avoid damaging the pads on the main board. Then, insert the wires into a new 3PDT board. Alternatively, you could use a new ribbon cable or wire, but ensure the pads are thoroughly cleaned out first. Be cautious when cleaning out the pads to avoid ruining them.
The four holes are for soldering a cap in place for those that feel they must have a cap.
June 12, 2024 at 4:15 pm #32499Anonymous
GuestThank you for your help. Can’t do new wiring board, however; can’t get the switch off the board.
What type of cap?
I’ll figure it out.
tx,
jeff
June 12, 2024 at 4:25 pm #32500
BarryKeymasterI meant you would need a new switch and wiring board. If you want it like it was designed to be.
You could also wire to a bare new 3PDT switch and include the CLR using one of the standard DIY guitar pedal wiring methods.
A cap is simply any cover you choose to use for the LDRs. You can attach four leads to a cap (either by gluing or soldering) and then solder it to the board to keep it in place. However, this is completely unnecessary. They were added because they take up “zero space” for those who insist on using a cap for unknown reasons, even though the back lid of the enclosure will do the same job. The pads are not connected to anything in the circuit.
June 13, 2024 at 6:37 am #32517Anonymous
GuestGood morning!
I sent you an email.
Let me know if you did not get it.
tx,
jeff
June 13, 2024 at 1:50 pm #32522
BarryKeymasterCheck your email for my response.
July 1, 2024 at 12:21 pm #32689Anonymous
GuestI apologize in advance for not knowing how to post this, but I just built the NT VIBE and it seems to work, but the yellow led is not pulsing? It’s a GREAT sounding preamp, but I was hoping for the Vibe vibe? I suspect the TL074 but who knows? Speaking of which? Does ANYONE know? I am open to suggestions. Thank you everyone!
July 1, 2024 at 2:08 pm #32690
BarryKeymaster@Todd
First since I cannot see. Did you use a non-conductive PCB spacer per the instructions between the metal circles of the Dual Gang pot and the PCB solder side containing 1n5817?
If that is not it I might suspect your TL074. It is easy enough to replace with a known working chip since it is socketed. The LED needs to be pulsing all the time, so that is easy enough to check as well.
Other things to try if that doesn’t work.
- Re-flow all of your solder joints on the back of the PCB.
- Take voltages and report for TL074, TL072, Q1, and Q2
