Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Need help with Roto-Tone Deluxe
- This topic has 15 replies, 4 voices, and was last updated 2 years, 10 months ago by
November 27, 2023 at 10:30 am #30201
GuestI’m attempting to use the Roto-Tone Deluxe as an onboard, in control cavity rotary/varitone switch. I’ve followed the diagram and used a Cody switch so that I can get 8 cap values out of the board. However, not sure how to properly ground and/or wire it into the guitar as I would with a normal rotary switch since it’s connected into a pcb. Any help or diagram would be tremendous!
November 27, 2023 at 12:12 pm #30202
CybercowParticipantNo idea what a “Cody switch” is. Can you please clarify?
And the Roto-Tone Deluxe does not support 8 device options – only 4.
We need more information on what you’re chasing.
November 28, 2023 at 12:40 am #30209Anonymous
Guest<p style=”padding-left: 40px;”>
Sorry – typo – I meant using a dpdt switch. Per the instructions with the Roto-tone deluxe, you can get up to 8 values using the dpdt switch. One for each leg of the rotary switch / one for each quadrant of the Roto-tone deluxe. My attempt in this is to use this pcb with the included mini 1-pole 8-position rotary, combined with the dpdt switch, using 8 separate capacitor values and create a pcb version of the varitone switch. Hope this helps. What I’m confused on is where the ground would come from off the board as well as where the ‘hot’ wire would come from to connect to the volume pot.</p>November 28, 2023 at 12:46 am #30210Anonymous
GuestI have it put together (took this pic before adding in the dpdt switch) and wiring it exactly as the diagram (previous post) shows. Just do not know where to wire the ground or hot in this instance.
November 28, 2023 at 1:55 pm #30219Anonymous
GuestSince I wrote the article for the RotoTone Deluxe, I can add this information:
First, the rotary switch only has 4 (four) positions. The addition of a DPDT switch as shown will permit the selection of 4 (four) more capacitors that are placed in the B to D positions. If you were to use four small value capacitors in the A to C positions and then four larger value capacitors in the B to D, the DPDT switch would then be selecting a high and low range of values.
I did a similar project to select four values for the WAH pedal. I found 4 different values provided quite a large variance of tones.
As the board and switch are only replacing a single capacitor position on the original circuit, there is no need for a separate ground or power connection.
I hope this helps.
November 28, 2023 at 8:04 pm #30227Anonymous
GuestWilkie1: So, I’m attempting to use this same setup you mention and that I’ve taken a picture of (minus the dpdt switch that was attached after pic was taken, that has a total of 8 (placed as you and the diagram explains) 50v small polypropylene capacitors that provide a total of eight tones ones the rotary is engage in each of the 4 positions and then after the dpdt switch is engaged, the other 4. My question and where I’m stuck, is how to I incorporate this into my guitar control cavity and connect to a hot and ground source, as I would with a varitone switch without a pcb board/ dpdt switch? That’s how I’d like to use the Roto-tone deluxe pcb with accompanying dpdt switch; this, replacing a tone pot on the guitar. Can this be done and if so, what is the missing step to connect it?
November 29, 2023 at 9:50 am #30230Anonymous
Guestto reiterate, this is to be used as a standalone pcb connected to a guitar, so ground and hot are vital to its operation, to become exactly as a varitone switch, but pcb-based. Can anyone help me?
November 29, 2023 at 9:53 am #30231Anonymous
GuestI’m basically trying to duplicate one that Epiphone has already done, but not at the Amazon price of $50 per, with all the added junk attached.
November 29, 2023 at 4:33 pm #30237Anonymous
GuestTry connecting the IN wire in the Roto-tone/DPDT diagram above to the lug 3 of the VOL pot. Connect the OUT wire to GROUND.
November 30, 2023 at 12:09 am #30244Anonymous
GuestThank you my friend! Thank you x 1,000,000,000!!!!!!
January 11, 2024 at 12:01 pm #30687Anonymous
GuestSorry guys, I’m the original poster an fam still having difficulties
upstanding how to make this work. I have ZERO issues taking a 1p12t rotary switch, a 2p6t rotary switch, etc and turning it into a varitone switch for all my guitars, connecting it to either the volume pot, or directly to the jack. I even use the audio xicon audio transformers to boost the passive power. But for some reason, even as easy as the layout is with this RotoTone delixe, I can’t get my head wrapped around the placement of my capacitors. I like to include resistors I parallel for each cap to prevent the pop, but am even willing to forgo that just to make this work, using in combination the recommended DPDT switch to give 8 values using the mini rotary. I’ve purchased around 50 of these, thinking no problems and would make tons of these for guitarists like myself, tired of big, bulky Alpha varitone switches that consume a large portion of the guitar control cavity. I just cannot, for the life of me, make it work. I’m wondering and hoping that someone smarter than me (that makes pretty much all of you) can just tell me exactly where, using the following photo direct from the rototone deluxe manual, exactly which areas I would place 8, small (50v) poly caps of varying values, I combination with a SPDT switch, so I would end up with a working 8-tone rotary switch for a guitar. I could then figure out the introduction of the audio transformer and hookup connection part of things. Can someone please show me?January 11, 2024 at 3:27 pm #30704Anonymous
GuestYou cannot add resistors in parallel with each capacitor. That would change the filter values beyond the frequency ranges desired.
The ROTO TONE DELUXE document does not show parallel resistors.
Simply connect the IN and OUT wires of the DPDT switch to Lug 3 of the VOL pot and GROUND as stated above. Four caps are connected to pads A to C and four caps are connected to pads B and D. I hope this helps.
January 11, 2024 at 3:57 pm #30707Anonymous
GuestPardon but It looks like the caps in the original photo are not mounted properly. They should each have only one leg per section in a given “quadrant” (for four caps), or one leg in a section and one leg in a “lettered row”. In the photo it looks like you’ve mounted both legs in a single quadrant section, shorting them out.
Sorry if this has been addressed!
—Edits in italics
January 12, 2024 at 1:18 am #30715Anonymous
Guestthank you both so much!!! mark, I do apologize, I meant in series. However, I completely get it. and thank you, Rob – THAT is the missing link…THE issue that is causing the problems. I cannot believe I missed that!!!
January 12, 2024 at 7:33 pm #30724Anonymous
GuestHappy to hear you understand the proper placement of capacitor legs between pads A and C and C and D of each segment. Don’t forget to remove the resistors!
Please forward a success story and final photo to help other forum members that are doing this procedure or are considering doing it.
January 14, 2024 at 8:23 pm #30750Anonymous
GuestHappy to help!
