  • #30144
    Want to switch up the character of your guitar with one stomp? Have two guitars you switch between? Want to use the same pedalboard for both guitar and bass?
    The left stompswitch is on/off, the right switches between EQ A and B, indicating which with the LED. That LED is always-on, so you know what you’re getting.
    The green is incredibly bright. Going to have to figure out how to tone down just that side. A resistor on the cathode?
    This is just two Tone Tweqs in one pedal. The sub/cut switches are 4PDT that switch between the stock bass-ready 220n capacitors and 68n to cut out subharmonics.
    The gut shot is… not the prettiest I’ve done. A few things are cludged together because of space. If I had done my layout properly ahead of time, I would have moved up a size just to make it easier, but a better hand than mine could make this decent. Probably going to have to chase down a ground loop somewhere when I figure out how to tone down the green LED, too.
    #30156
    Playsforfun
    Nice. I can see how that could be useful.
